AutoCAD P&ID General Discussion
Member
didierc
Message 1 of 4 (666 Views)
bug!!!
666 Views, 3 Replies
01-11-2013 04:31 AM
The messages below have been displayed by autocadP&ID, after i had save the file and also when i try to link two off page connector.
1.   PnP Completion Status. Failed To Accept Changed Some Kind of Disk I/o error occured disk I/O error!!!
2.   PnP Completion Status. Failed To Reject Changed PnP Completion Status. Failed To Accept Changed Unable to OPen the Database file unable to open database file!!!
if someone know how to resolve this problem, give solution please. thanks
Didier.
Employee
TomislavGolubovic
Message 2 of 4 (630 Views)
Re: bug!!!
01-13-2013 02:52 PM in reply to: didierc
Does it still do it if you close and restart the project?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Member
didierc
Message 3 of 4 (621 Views)
Re: bug!!!
01-13-2013 10:13 PM in reply to: didierc
Yes,
and i have got a new message.
Pnp Completion  Status. Failed To Accept Changed.
Abort due to constrain violation.
PRIMARY KEY must be Unique.
This message has been appeared after a link of, Off page connector.
Note that Off page connector works. see attachment.
Valued Contributor
georgeendrulat
Message 4 of 4 (598 Views)
Re: bug!!!
01-14-2013 11:40 AM in reply to: didierc
Have you tried to audit the project yet? Errors?
Worse comes to worse you can create a new project and copy all the drawings from the old project into the new one, that has worked for me a couple of times.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
