AutoCAD P&ID General Discussion
New Member
bspiker725
Message 1 of 2 (439 Views)
Autogenerate loop numbers based on area
439 Views, 1 Replies
01-21-2013 03:55 PM
Is there a way to autogenerate the loop number based on the area?  The scenerio is this.  We have a
plant with multiple areas and would like loop numbers to restart when I change areas.  Tags would look
like 100-FE-001 for a 100 area and 200-FE-001 for a 200 area.
Valued Contributor
georgeendrulat
Message 2 of 2 (407 Views)
Re: Autogenerate loop numbers based on area
01-22-2013 11:11 AM in reply to: bspiker725
You can assign a drawing property and refrence that within the tag.  If you have multiple areas per drawing it will become much harder, but not impossible.  If you are already creating area breaks like spec breaks, then a line property can be had with an aquisition from the line itself.  It would help greatly to know if you plan on having more than one area per drawing or not.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
