AutoCAD P&ID General Discussion
EileenForan
Message 1 of 11 (3,029 Views)
AutoCAD Plant 3D 2013 and AutoCAD P&ID 2013 Service Pack 1--Available Now
3029 Views, 10 Replies
12-06-2012 04:01 PM
In a continuing effort to provide high-quality products, Autodesk has released AutoCAD P&ID 2013 Service Pack 1 and AutoCAD Plant 3D 2013 Service Pack 1.
The service packs address many Isometric-related enhancements and modeling related to improve the productivity and accuracy.
NOTE: Before downloading the service packs, view the Readme
AutoCAD P&ID 2013 Service Pack 1.
Eileen Foran
Community Program Manager
Autodesk Plant Solutions
DuncanBrannan82
Message 2 of 11 (2,890 Views)
Re: AutoCAD Plant 3D 2013 and AutoCAD P&ID 2013 Service Pack 1--Available No
12-19-2012 06:38 AM in reply to: EileenForan
Hi Eileen,
We are trying to append this Service Pack to the P&ID 2013 Deployment Image with no luck unfortunately...
Basically, it doesnt recognise that the has been an SP released and when i extract the MSP, there is no way i can add it manually without creating a seperate ipf and exe.
Also, when trying to install manually straight from the download, we get the following pop up attached which we cannot get around... See P&ID Error.png
P.S - I have also attached the P&ID 2013.log file for more information.
If my post was helpful to you, please could you give "Kudos" and/or mark the "Accept as Solution" button(s) below. Thanks in Advance!
Duncan Brannan Send DuncanBrannan82 a Private Message
DuncanBrannan82
Message 3 of 11 (2,785 Views)
01-02-2013 06:28 AM in reply to: DuncanBrannan82
I was wondering if anyone else is having this issue as we are still having this problem when trying to install on top of P&ID.
Duncan
EileenForan
Message 4 of 11 (2,779 Views)
01-02-2013 10:06 AM in reply to: EileenForan
Hi Duncan. Sorry for the delayed response. I've asked our development team to look into the issue you describe, so I hope we can help you as soon as possible.
All the best,
Eileen
Eileen Foran
DuncanBrannan82
Message 5 of 11 (2,761 Views)
01-03-2013 12:04 AM in reply to: EileenForan
Many thanks Eileen, i appreciate your help :smileyhappy:
Duncan
Employee
sunlh
Message 6 of 11 (2,730 Views)
01-03-2013 06:19 PM in reply to: DuncanBrannan82
HI Duncan,
Have you tried to restart the machine and reinstall the downloaded EXE, without windows update or P&ID running?
Does the retry work for you when the error shows up?
Lianheng Sun (孙 连珩)
Software QA Engineer, ICP Plant Solutions
Autodesk Inc.
DuncanBrannan82
Message 7 of 11 (2,718 Views)
01-04-2013 03:05 AM in reply to: EileenForan
Hi Lianheng,
We always try this with any issue we have with software installs. As is, uninstalling, reinstalling and repairing an install. As a rule, we never try to install SP's while the original program is open.
Just so you know, we have tried to install the SP in both a user and admin profile with no luck... however, i have managed to install it on my test machine.
The machines we are trying to install these on both have Plant 3D and P&ID on, could it be an issue with the order they are installed possibly which is causing a conflict with Temp files?
Duncan
Employee
sunlh
Message 8 of 11 (2,693 Views)
01-06-2013 06:06 PM in reply to: DuncanBrannan82
Hi Duncan,
It should be a different reason, I always have these 2 products on the same machine and the installation goes well.
Unfortunately I haven`t got a solid repro of the issue on my machine. One thing came across my mind is to turn off UAC and try install SP - not sure if you have aleady tried.
One workaround to get the product patched - not that convenient:
1. compare files on the machines without SP and the test machine with SP installed, and copy the updated files manually. I attached a file list.
2. Update the registry "HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B016:409" for P&ID, "HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R19.0\ACAD-B017:409" for Plant 3D, set value "DisableAdConnect" to "0"
Lianheng Sun (孙 连珩)
Autodesk Inc.
DuncanBrannan82
Message 9 of 11 (2,639 Views)
01-11-2013 05:35 AM in reply to: sunlh
All,
I can confirm that we eventually managed to fix this but it meant doing a clean uninstall and reinstalling again. However, you need to be careful when you manually add the SP1's.
What i did, was use the following... http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617 to remove the products, i then restarted the machine, proceeded to install them again, once installed opened the product and then closed and then installed the SP.
The first time you try to add the SP you will get the following options... Retry, Cancel or Ignore. If you retry and cancel when you run the SP again the option to Ignore has gone so you miss your opportunity to install.
What you need to do when either pop up presents itself, click on ignore and it will continue to install the SP.
Unfortunately you cannot append these to Deployment Images which is such a shame, hope it gets resolved soon :smileyhappy:
Duncan
Distinguished Contributor
Brausmith
Message 10 of 11 (2,414 Views)
02-10-2013 05:02 PM in reply to: EileenForan
When extracting the AutoCAD Plant 3D 2013 Service Pack 1 the result are two files which are considerably smaller then the original .exe, about 25% smaller.
We get;
autocad_plant_3d_2013_x64_sp1_glob.msp - 25,529kb
autocad_plant_3d_2013_x64_sp1_lp.msp - 488kb
Is this correct?
It seems unusual for the extacted files to be much smaller than the source.
Chad
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
