AutoCAD P&ID General Discussion
Member
0 Kudos
Post 1 of 6
Autocad P&ID Flow arrows
1016 Views, 5 Replies
02-07-2012 12:56 PM
We are using AutoCAD plant for a project.  When we go to plot the flow arrows on the P&IDs shown in the program are not showing up on the plot preview.  Is there any reason this would happen?  Please see attached and advise!!! Thanks.
Member
0 Kudos
Post 2 of 6
Re: Autocad P&ID Flow arrows
02-07-2012 01:00 PM in reply to: brian
I am having the same exact issue.
Valued Mentor
80 Kudos
Post 3 of 6
02-07-2012 01:57 PM in reply to: Dennis_W
Do you have last service pack installed? Attach dwg file here for review
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Active Member
0 Kudos
Post 4 of 6
02-11-2013 03:57 AM in reply to: brian
Was there ever a solution for this found? I'm currently deal with this issue is 2013, my flow arrows are showing on screen on the drawing but on print previews and plots they're nowhere to be seen. The same is also happening for the solid hatched ends to my off-page connectors. I have deleted and re-created the symbols in project setup, I have opened the drawing on different machines and I have re-installed the software. The flow arrows show as they should when the drawing is exported from P&ID to normal AutoCAD.
Employee
52 Kudos
Post 5 of 6
02-14-2013 11:41 AM in reply to: otto2010
I had someone use custom flow arrows, and they didn't plot. When we delved into it, there was something with the hatch/color/layer of the block, that didn't let it plot.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Active Member
0 Kudos
Post 6 of 6
02-18-2013 01:29 AM in reply to: brian
Since my last post, I have re-drawn the symbols and re-added them - exactly as they were before with the solid hatching on the same layer as previous - and they are working fine now. I suspect it had something to do with them originally being drawn in a previous version of the software but I'm not sure. Thanks for your reply.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
