AutoCAD P&ID General Discussion
Member
zaratedd
Message 1 of 4 (417 Views)
AutoCAD P&ID 2012 Open drawing error
417 Views, 3 Replies
10-16-2013 08:31 PM
Hello, I just installed AutoCAD P&ID 2012 (64Bit, Win 7), while trying to open the sample drawing file: PIP-01-101.dwg
I get an AutoCAD Message Dialog box,  'An error occurred while attempting to open the following drawing'. This or any other drawing will not open after the program loads. I'm new to P&ID but not to Autodesk family of products, Any help to resolve this issue is greatly appreciated. Txs, --DZ
Employee
KenFauver
Message 2 of 4 (318 Views)
Re: AutoCAD P&ID 2012 Open drawing error
11-27-2013 12:39 PM in reply to: zaratedd
This probably has to do with using the Sample Project under the Administrator Windows profile. Before doing any further testing it is recommended you create new project on C: drive in order to not have the permissions limitation.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
Member
zaratedd
Message 3 of 4 (310 Views)
Re: AutoCAD P&ID
11-27-2013 02:51 PM in reply to: KenFauver
Ken,
Thanks for the response. Actually the reason was I was using a copy of the
student version of Acad P&ID. All .dwg files to be opened in Acad P&ID
Student version need to be open first and saved, else you get the error. I
do appreciate your response.
David Zarate | Owner USM | Ontario, CA
Member
zaratedd
Message 4 of 4 (310 Views)
11-27-2013 02:52 PM in reply to: KenFauver
Ken,
Thanks for the response. Actually the reason was I was using a copy of the student version of Acad P&ID. All .dwg files to be opened in Acad P&ID Student version need to be open first and saved, else you get the error. I do appreciate your response.
Thanks again,
Announcements
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
