AutoCAD P&ID General Discussion
Member
pmccartney
Message 1 of 3 (553 Views)
Accepted Solution
AutoCAD P&ID 2012 (Not Responding) after selecting "project.xml"
553 Views, 2 Replies
04-17-2012 11:38 AM
This has happened a couple of times where only one of our designers is able to access a particular project, and nobody else can. What happens is, as soon as the "project.xml" file is selected from the Project Manager, AutoCAD P&ID locks up and is no longer responding. Task Manager has to be invoked to "End Task" in order to regain control. I've looked at all the XML files and I've even gone into the project properties of the project on the only workstation it doesn't lock up on, and still we can't get into the project. What's worse is the fact that the other designers were able to get into the project before. I've also looked for lock files, and nothing seems to be out of the ordinary.
Any suggestions on how to remedy this would be HIGHLY appreciated.
Try running the local data cache purger application:
http://www.pdoteam.com/2012/03/plant-3d-startup-hanging/
*Expert Elite*
dave.wolfe
Message 2 of 3 (551 Views)
Re: AutoCAD P&ID 2012 (Not Responding) after selecting "project.xml&quo
04-17-2012 12:53 PM in reply to: pmccartney
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Member
pmccartney
Message 3 of 3 (547 Views)
Re: AutoCAD P&ID 2012 (Not Responding) after selecting "project.xml&amp
04-17-2012 01:13 PM in reply to: dave.wolfe
Thanks Dave. That appears to be the solution we were looking for. Everything seems to bee working now.
Phil
Post to the Community
New Post
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
