AutoCAD P&ID General Discussion
0 Kudos
Post 1 of 5
Assemblies in AutoCAD P&ID??
1541 Views, 4 Replies
12-03-2010 01:54 PM
Another rookie question here but can you build assemblies in AutoCAD P&ID?.  I cant seem to find the assembly enviornment . . . .
Product Support
55 Kudos
Post 2 of 5
Re: Assemblies in AutoCAD P&ID??
12-05-2010 12:38 PM in reply to: Homskillit
It is possible to create commonly used assemblies in P&ID. What you want to do is create a block for your assembly and add it to the tool palette.
For example, here is a simple pump instrument loop:
 2320i942760B8131A7ED5
Steps to create an assembly of this:
1. Select all of the objects to be included in the assembly
2. Convert these to a block using the BLOCK command (select a logical insertion point)
2324i971045309D86CF10
3. Save the drawing, then drag the block over to the tool palette
2326i2FDA1FD9B794D1E4
To place the assembly in a drawing:
1. Use the tool palette just as you would for any symbol
2. Select the assembly and use the EXPLODE command
3. The assembly items are now placed and ready to use
One thing to note, on any tagged objects such as equipment or instruments make sure you leave the item tags blank before creating the assembly. That way you can place the assembly over and over and just assign the tags once it's placed in the drawing.
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
0 Kudos
Post 3 of 5
12-06-2010 08:45 AM in reply to: Homskillit
Thank you very much for that.  Actually, what I was looking for was the 3D assembly enviornment.
I was able to create a 3D assembly using blocks but I couldnt find the "Insert Components" or other assembly commands.
I was using the acad3D template but I wanst able to ind any assembly commands.
Does AutoCAD P&ID have 3D assembly capability?
Distinguished Mentor
10 Kudos
Post 4 of 5
12-06-2010 03:46 PM in reply to: Homskillit
You'll want Inventor.
Valued Contributor
2 Kudos
Post 5 of 5
10-18-2012 12:33 AM in reply to: jason.drew
One additional question on assemblies:
When I insert the assembly in my tool palette, I can use it over and over again.
But if I want to change one object in the assembly, all my drawings won't recognize the changes I made.
(Even if I do not explode the assembly)
Can this be achieved somehow?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
