AutoCAD P&ID General Discussion
New Member
bradley.svoboda
Message 1 of 2 (278 Views)
ANNO AND DISAPPEARING TEXT
278 Views, 1 Replies
01-09-2013 10:16 AM
I created a new anno for one of the blockS, put the information in and it stays there until I go into the project setup. It disappears when I go back into the drawing.
Valued Contributor
georgeendrulat
Message 2 of 2 (234 Views)
Re: ANNO AND DISAPPEARING TEXT
01-14-2013 11:43 AM in reply to: bradley.svoboda
Can you verify that the block that you are using for the annotation is located somewhere that the drawing can see.  Can you verify that the layer inside the block is 0.  Can you verify that the block is useable on it's own in a non-p&id dwg. Can you verify that the data inputted within the block is there.  I'm thinking it's a block problem not a P&ID problem.
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
