AutoCAD P&ID General Discussion
Member
krishna
Message 1 of 2 (354 Views)
A New Problem in P&ID - A bit urgent !!!!
354 Views, 1 Replies
12-25-2012 03:38 AM
Dear Experts,
          We have a valve symbol like the attached one. I tried to create the same with AutoCAD P&ID. But, I couldn't make the exact symbol what i wanted. I'm able to create the symbol like (3), but I want to creat the symbol like (1) & (2). Could some one pls help me to do the same? A bit urgent.
Valued Mentor
ybogdanov
Message 2 of 2 (349 Views)
Re: A New Problem in P&ID - A bit urgent !!!!
12-25-2012 04:22 AM in reply to: krishna
I think that the problem which you have is type of connection. In this moment is not posible to use diferent type of connection for each port.
 The solution for you could be to create this valve with flanges in the same block, and don't use any type of connection(undifined type).
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
