AutoCAD P&ID General Discussion
craig.wood
Message 1 of 10 (846 Views)
2014 Off Page Connectors (No plot icons?)
846 Views, 9 Replies
05-20-2013 11:12 AM
Is there any way to toggle the OPC status icons (connected, connected with inconsistencies, & not-connected) to either plot or not plot? The default setting appears to plot these icons on our pdfs, which we would like to change to not have them plot.
I've checked the help menu but find no mention of how to change the status icons to "not plot".
Thanks in advance,
Craig
craig.wood
Message 2 of 10 (823 Views)
Re: 2014 Off Page Connectors (No plot icons?)
05-21-2013 08:12 AM in reply to: craig.wood
Just to clairify, we are trying to generate our pdfs out of the BlueBeam plugin, not the standard ACAD plot menu (ctrl+P). I'm going to get in touch with BlueBeam about this, but it would be nice if there was a command to toggle the display on these icons to plot or no-plot.
Craig
*Expert Elite*
Rave.Tam
Message 3 of 10 (808 Views)
05-24-2013 10:24 PM in reply to: craig.wood
Does not seems to have problem with the normal AutoCAD plot command. Must be the problem with the plugin you used.
Don't think there's a in built command to turn it off. Try modify the content of OPC block and place it to another layer. Then when using the OPC, place it into a layer which is off by default. The icon should dissappear now.
If my post answers your question, please click the "Accept as Solution" button.
Check out my blog http://lazcad.com
craig.wood
Message 4 of 10 (772 Views)
06-06-2013 09:45 AM in reply to: Rave.Tam
Thanks Rave,
Yeah you're right, the regular plot command using BlueBeam as the printer works fine, but most of my team uses the plugin to also do batch plots. It's more of a long-term request as I can still publish the drawings in the meantime for clients' viewing (without the status icons). I have yet to try the layer change method you outlined in your post, but will have to check that out as well.
I just hope that either Autodesk or BlueBeam will come up with a method to allow the icons to either be toggled yes/no-plot or an option to filter them out of the pdf. Autodesk created the icons, but they only plot while using the BlueBeam plugin, so I don't know who is ultimately responsible.
Craig
craig.wood
Message 5 of 10 (711 Views)
07-10-2013 11:55 AM in reply to: Rave.Tam
We took a ticket out with BlueBeam. They said they would include an update with a fix sometime soon.
Craig
SteveDarvell
Message 6 of 10 (501 Views)
11-03-2013 06:50 AM in reply to: craig.wood
Has anyone found a way of turning off these status icons.
I have just migrated a project to Plant 3D 2014 with 35 sheets, each with a load of OPCs. When I use the "publish" command to generate a multi sheet .pdf file I see the icons displayed but if I use the print command on individual sheets I can get a clean drawing with no icons.
This leads me to the p[roblem that the work around appears to be that I need to go into individual drawings and plot to .pdf then go into adobe or similar software and create a multi sheet drawing to combine them all into a single drawing.
Am I missing something or am I going to have to spend the extra time plotting off the drawings and then combining them together rather than the established publish command which I have used perfectly well in the past.
craig.wood
Message 7 of 10 (492 Views)
11-04-2013 07:52 AM in reply to: SteveDarvell
Hey Steve,
The method that I've been using, although not the most ideal, is to publish a set of drawings to .dwfs, then use a .dwf to .pdf conversion utility to finish the job. This method has worked the best for us, although the downside is that the pdfs are made rasters and lose their vector properties (ie: BlueBeam doesn't recognize text as text, but just everything on the pdf as one big image file).
I hope this helps.
Craig
If my post is a solution to your issue, please click "Accept as Solution" below...
Member
davidcruze
Message 8 of 10 (298 Views)
02-28-2014 08:53 AM in reply to: craig.wood
Go into your options and turn off the Publish in Background. This will prevent the OPC status icons from displaying in your sheets sets when publishing.
Member
steve
Message 9 of 10 (276 Views)
03-03-2014 01:01 PM in reply to: davidcruze
David
Thanks for the response, it worked great for me.
Cheers
Member
davidcruze
Message 10 of 10 (274 Views)
03-03-2014 01:10 PM in reply to: steve
Steve,
Glad to hear it! Happy to help out. I will start looking out for more
posts on Plant & P&ID to assist in trouble shooting.
Take care!
David Cruze
AEC & Plant Solutions Engineer
Autodesk Certified Instructor
Hagerman & Company, Inc. | 10025 Investment
Dr - Suite 250 | Knoxville, TN 37932 | (865) 539.2817 x692
Need installation help?
New AutoCAD P&ID Category!
The AutoCAD P&ID forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
