Well, then I suggest that the autolayout shall have selection of the length
and angle when this transition is set as default. What you described it is
really tiresome, but what do we have now? Draw the duct, change dimension of
the duct which causes default transition is inserted, then click on
transition to modify it, select different part, select desired length or
angle, correct broken layout. I'm not sure whether this is much better. On
the other hand using Insert fitting command is not so convenient, either. By
some reason it is not so obvious whether the fitting inserts in right
direction and at right angle to the axis.
sp
"Peter Terwilliger [Autodesk]"
wrote in
message news:7FBE0AB9309F16DD7AE5564B28107518@in.WebX.maYIadrTaRb...
> Slawomir -
> They are not available to autolayout since they have multiple solutions to
> solve one problem. For example, the autoinsertion routine is not smart
> enough to figure out what length you want the 10" to 20" transition to be.
> Let's say you turned on the autolayout flag in Content Builder or Catalog
> Editor and then set this fitting as your preference for transitions. So,
> you are cruising along and change sizes -> multiple fittings found error
> message. Okay, no problem, you pick a length. But, now the application
> will use that length as the default everytime you need to use that
fitting.
> We thought that the inconvenience of that would outweigh any benefits of
the
> autoinsert so we turned the flag off.
> Unfortunately, ABS does not yet give you the ability to specify properties
> in the default fittings dialogs.
