AutoCAD MEP Wishes
AutoCAD MEP Wishes
Active Member
brandon0403
Message 1 of 1 (274 Views)
Tag Anchor [3A72], Broken reference, Release Anchor
274 Views, 0 Replies
05-11-2009 01:48 PM
Room name/number tags are disappearing in a drawing I received from an architect. The drawings were sent using the eTransmit tool to create a .zip file. When AutoCAD tries to regenerate the model after loading all the X-Ref's it gives me the following message...
Regenerating model.
Enhanced reference audit problems for database "C:\Documents and
Settings\brandon\Desktop\New Folder\Second Floor Plan.dwg"
(in the form: "Name, Reason, Repair Method"):
Tag Anchor [3A74], Broken reference, Release Anchor
Tag Anchor [3A76], Broken reference, Release Anchor
Tag Anchor [3A78], Broken reference, Release Anchor
Tag Anchor [3A7A], Broken reference, Release Anchor
Tag Anchor [3A7C], Broken reference, Release Anchor
Tag Anchor [3A7E], Broken reference, Release Anchor
I tried attaching the x-ref instead of overlaying it, but did not solve the problem. I realize I may have not included enough information to obtain a solution, just ask and I will provide any further information I can.
Brandon
