AutoCAD MEP Wishes (Read Only)
symbol of conection electrical an plumbing are too big and hide the objet
0 REPLIES 0
Message 1 of 1
rmendezb
1557 Views, 0 Replies
Hello.
I'm  learning Autocad MEP .
mi drawing setup:
units meters.
i did inserted (for plumbing) any equipment with terminal for conections and for each one of the conection there are one symbol (triangle with !)  my problem is the size of this symbol, is too big!!  and i can't resize it  , if i turn off his layer, all this objet is invisible.
The image attached: four viewports of my problem:
upper left, turned contour invisible. the symbol turned off. the objet is too small. the zoom is similar to viewport upper right.
lower left viewport the same objet zoomed. lower right viewport = upper right
The diameter of this simbol is   0.10 meter
Thanks. I can't work with many objets, all them has its own symbol(s) for each conection!!!
0 REPLIES 0
