AutoCAD MEP Wishes (Read Only)
.PGP file Location - Command File Location!!!
3 REPLIES 3
1093 Views, 3 Replies
Hi Guys,
I was just wondering if anyone of you guys would know how to locate the ".PGP" file that has all the short cut commands for AutoCAD MEP.
In the regular AutoCAD programs, if I'm not mistaken it was under "Tools". I couldn't find it in AutoCAD MEP and this is my 2nd week using this new AutoCAD. Any help would be much appreciated.
Thanks.
3 REPLIES 3
If you have express tools loaded it is found on the ribbon button for
command aliases or you can type in aliasedit
"dzamani" wrote in message news:6228004@discussion.autodesk.com...
Hi Guys,
Thanks.
Hey Mike,
Thanks for reply. I actually found it and it's not part of the Express Tool options, but rather found under "Manage ==> Customization ==> Edit PGP"
Thanks anyways.
Cheers.
You are correct, I was approaching it from the dialog editor not the notepad
editor. Your way is much better, thanks for the additonal information,
instead of me helping you, you helped me!
"dzamani
Hi Guys,
Thanks.
