J,
I just got around to really testing this and isn't working as expected.
I am attaching a basic example. Could you take a look at it? I made a
solid box 24" cubed and etched a circle in the top. After the MvPart is
made, the circle shows in iso view but not in top view. I made sure the
circle is exactly on the top view plane. Any idea what I am doing wrong?
Andrew
AndrewT wrote:
Thanks J, that works great. I can even draw access doors, etc. on the side!
Andr
ew
J [Autodesk] wrote:
No need to raise any edges off the solid face by .001 or fake it out.
There is a solids edit toolbar with a bunch of goodies that has been
there for a long time in plain Acad (Probably little known in our
industry, maybe well known by manufacturers who design solids all the
time). On this toolbar, is a command to "Imprint" the solid surface. You
draw a primitive like a line, arc, circle, etc on the surface of your
solid...it mus
t be exactly on the plane of the surface...then hit the
Imprint button and it will "scratch" Imprint the surface of the solid.
J (Autodesk)
AndrewT wrote:
Thanks for the tip. What exactly are you using to etch the solid?
I've been using the workaround of making every other section slightly
taller than the others. For instance, sections 1, 3, 5 would be 45"
while sections 2, 4, 6 would be 45.001.
J [Autodesk] wrote:
Andre
w,
You can get around this solids behavior by "Etching" the solid. Don't
slice the overall solid into multiple, but maintain the body as 1 piece
and use the Etch feature. In the past, I did this myself to designate
the duct connections as supply & return X & Y.
J (Autodesk)
AndrewT wrote:
Sample image.
