AutoCAD MEP Wishes (Read Only)
MEP 2012 Tool Palette
1 REPLY 1
sinannajm.m
1936 Views, 1 Reply
Please help me, I was trying to alter the standard blocks on the tool palette. I have no idea how I messed everything up but I basically have two huge problems now.
1. I am missing the necessary default blocks that should be under my edit block directory.....all the Aecb files.
2. Now when I try and put in a receptacle or any other standard block a triangle with an exclamation point shows up upon insertion.
Please help me get everything back to normal.
Thank you,
Sinan Najm
I attached a picture of the "edit block definition" and the troubled smybols. Any and all help would be hugely appreciated.
1 REPLY 1
Keith.Brown
in reply to: sinannajm.m
If you have modified the blocks and need to revert to the original then just copy them over from the autocad template.  You did make a copy of the template before you started modifying it right?
The exclamation points in the triangle merely mean that their is a connection that is not complete on the object.  You have probably turned on that feature under the views tab ->MEP Views -> Solution Tips.  This is normal and doesnt mean anything is broken.
