AutoCAD MEP Wishes (Read Only)
andrew.warren
2636 Views, 1 Reply
Measure Pipe Run
Why is their not a tool when you select a pipe run to get the information about it. I understand many have branches and such but maybe multiple answer tool (ie Maximum Run length from beginning to the end of the furthest run, then total length of pipe and fittings [with a sub of total length of pipe without connectors]. I know you can do a schedule to do this, but I don't even do pipe schedules (should but that is a work problem not software). I just need to know the max length and total length for estimates for ordering pipe and working with the contractors.
Come on Autodesk, I know you guys can do this... Smiley Wink
Andy Warren
BCDesign@bellsouth.net
1 REPLY 1
Have you tried the tool on this thread:
http://forums.autodesk.com/t5/AutoCAD-MEP/Overall-conduit-length-end-to-end-including-fittings/td-p/...
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
