Hi Aaron -
The display of the "haloed" lines is controlled by the display of the
?-Halo-High and ?-Halo-Subd layers (? is probably M in your case, but may
also be E). If you change the linetype used by that layer you will be
changing the linetype of the hidden lines. Change the linetype to Hidden2
and you will see twice as many "dashes" (you may need an objrelupdate).
hth
jason
"Aaron"
wrote in message
news:89D7BB591468CD9827D07BD677B92A9D@in.WebX.maYIadrTaRb...
> The hidden line mode is a great improvement and offers some fantastic
> options, but I am having problems adjusting the line type scale when
> applying the hidden line mode. I would like to see more small dashes
instead
> of only a few. I have not been able to figure out how to control these
> settings....
> Thanks,
> Aaron
