AutoCAD MEP Wishes
AutoCAD MEP Wishes
Distinguished Contributor
0 Kudos
Post 1 of 5
Ghosted Labels so you can see where to put them
88 Views, 4 Replies
07-23-2003 12:19 AM
Ghosted Labels so you can see where to put them. Offsetting labels is a pain to try and place since the text does not ghost when trying to relocate it. Not uncommon to have to move the test 3-4 times to get it exactly where you want it.
Active Contributor
0 Kudos
Post 2 of 5
Re: Ghosted Labels so you can see where to put them
07-23-2003 01:28 AM in reply to: jmcfaddn
Even better if you can move labels with standard Autocad move or stretch command
Re:
07-23-2003 05:14 AM in reply to: jmcfaddn
Or even grips.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">Even
command
0 Kudos
Post 4 of 5
02-12-2004 12:50 PM in reply to: jmcfaddn
It would be great to be able to place the label with an option to either place the duct text label inside the duct as default, as well as a variable that would allow the user to place the duct size label manually. Offsetting the nodes is definitely tedious and time consuming. The ghost idea is nice but I would rather not have to move the text at all once I placed it.
0 Kudos
Post 5 of 5
07-26-2004 08:18 AM in reply to: jmcfaddn
Ghosting is a good idea. What about just enabling grips to labels/flow arrows. Grips would be so much easier than the current offset node.
