AutoCAD MEP Wishes
Member
boytigger
Message 1 of 2 (140 Views)
dynamic section cutting tool
140 Views, 1 Replies
04-04-2003 05:13 AM
please go back to softdesk 8 and pull out the section cutting tool. when working in 3d, the ability to cut a section to clear up a view to work on certain areas is invaluable. dview takes too many steps which means too much time.
Active Contributor
wskene
Message 2 of 2 (140 Views)
Re: dynamic section cutting tool
01-20-2006 07:42 AM in reply to: boytigger
You can cut a section to work in 3D using the isolation tools.
First select the objects then right click, then go isolate objects.
You can isolate in section, elevation, plan, or just isolate objects and this will allow you to work in 3d on the objects selected.
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
