AutoCAD MEP Wishes (Read Only)
Duct Transition Offset Request
4 REPLIES 4
advandes
300 Views, 4 Replies
It is not uncommon to have to create a duct fitting that not only transitions from one rectangular size to another but also is offset. I assume this software will not create such a fitting. The simplest way I can see doing this (my suggestion) is for the user to create the 2 sections of ductwork at there respective X,Y and Z location,leaving out the transition/offset and then selecting a NEW command that prompts the user to select each duct and "WOLLA" a Transition/Offset fitting is created between the two ducts. A must need in the real world!
Thank you,
Aaron
P.S.
Jason, you are awsome...quick responses and very helpfull..A++++
AAG
Advance Design
4 REPLIES 4
advandes
in reply to: advandes
I meant "VOLLA"....My Italian is a little off today...
AAG
Advance Design
Isn't that "volia"? 😉
R. Robert Bell, MCSE
www.AcadX.com
"advandes" wrote in message
news:f166bfe.0@WebX.maYIadrTaRb...
advandes
Actually I think it's "voila".....anyway, how about that transition question, anyone?
Aaron
AAG
Advance Design
Aaron -
The desired fittings are part of the ABS 2004 HVAC
Content Extension.
I hope this helps!
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
