style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"WICK" <I
href="mailto:wick_01702@yahoo.com">wick_01702@yahoo.com> wrote in
message
href="news:f193b2c.-1@WebX.maYIadrTaRb">news:f193b2c.-1@WebX.maYIadrTaRb...
am trying to figure out how to customize the right-click shortcut menu. I want
to put all the "Basic Modify Tools" back into the main part of the shortcut
menu, like it was in previous releases. I use these commands a lot and it
would save some time if I didnt have to wait for the second pop-up menu. I
went through the help menu and it said that I can customize the shortcut
through the acad.mnu file, but I cant figure out which part refers to the
shortcut.
"Hakan Wikemar [Autodesk]" <
href="mailto:hakan.wikemar@autodesk.com">hakan.wikemar@autodesk.com>
wrote in message
href="news:5A6E6BF9CEEEE81CA8DE5F6FE071DF2C@in.WebX.maYIadrTaRb">news:5A6E6BF9CEEEE81CA8DE5F6FE07......
Hi Wick.
Are you talking about customization of the
menus the BS2004 release? If so, look for the loaded menu file BSDT4.mnu
instead. (Per default located in: C:\Documents and
Settings\yourusername\Application Data\Autodesk\Autodesk
Building Systems 2004\R16.0\enu\Support
Modify this file, then run menuload and
reload the modified BSDT4.mnu (to recompile the menu
file)
The menu item I think you are interested in
is the ***POP501 thingie.
I have made a new menu file to simplify the
identification of each menu item, (just added the ***POP# to each menu) load
this one first instead of your original mnu file (use menuload unload the
original file and load mine)
Before you do anything, please make a back up
copy of your original BSDT4.mnu
Hth
/Hakan
"WICK" <I
message
want to put all the "Basic Modify Tools" back into the main part of the
shortcut menu, like it was in previous releases. I use these commands a lot
and it would save some time if I didnt have to wait for the second pop-up
menu. I went through the help menu and it said that I can customize the
shortcut through the acad.mnu file, but I cant figure out which part refers
to the shortcut.
"WICK" <How
message
href="news:f193b2c.2@WebX.maYIadrTaRb">news:f193b2c.2@WebX.maYIadrTaRb...
can I get a copy of the file you said you made?
