AutoCAD MEP Wishes
AutoCAD MEP Wishes
sinannajm.m
Message 1 of 3 (1,503 Views)
Create 2d blocks that have 3d models attached to their definition!
1503 Views, 2 Replies
07-03-2012 11:48 AM
How does autocad create 2d blocks that turn into 3d models when you switch views?
Keith.Brown
Message 2 of 3 (1,495 Views)
Re: Create 2d blocks that have 3d models attached to their definition!
07-17-2012 10:58 AM in reply to: sinannajm.m
This is the Autocad MEP Wishes forum and this question is not really appropriate for this forum.  But to answer your question, both Autocad MEP and Autocad Architecture use what is called a mvblock.  A mvblock has the ability to use a different block for each view.  So for instance, if you are in a 2D view (TOP), you can assign it a 2D block to display. You can then assign it a 3D block to display in you are in an isometric view.  I hope this answers your question.
Keith Brown AutoCAD MEP BLOG | RSS Feed
AutoCAD MEP 2014 | Revit 2014 | EastCoast CAD/CAM V6.1 | Visual Studio 2013
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate. Thank you!
Valued Mentor
smbrennan85
Message 3 of 3 (1,489 Views)
07-18-2012 06:37 AM in reply to: sinannajm.m
To expand on Keith's response, you can also control each of the 6 views and what block(s) are displayed. So, if you are doing an elevation view, you can create a mvpart that has an elevation block while looking at the front. It doesn't have to be a solid. You can also attach as many blocks you want. I'm sure there's a limit, but I can't see a reason anyone would come close to that limit.
Shawn B.
Follow me on Twitter @That85CADGuy.  ||    Connect with me on Linkedin.
To help improve Autodesk Products, please Click Here to provide feedback.
To help improve the use of these Forums, please  Accept As Solution and  Give Kudos.
