I use MEP AutoCad to 3D model conduit runs. Does MEP have a option that after I finish modeling a conduit run it would tell me how many degrees I have put into that conduit run.National electrical code requires that no conduit run have more than 360 dgrees.After that a pull box is required .It would help if as I run the conduit throughout the building ,if I exceed the 360 degrees it would prompt me that a pull bow is requred.Or another way if after I finish the run I have a option that would add the pull boxes as needed.Any help?
