AutoCAD MEP Wishes (Read Only)
Counting bends in a conduit run
0 REPLIES 0
Message 1 of 1
dennishansen
1635 Views, 0 Replies
I  use MEP AutoCad  to 3D model conduit runs. Does MEP have a option that  after I finish modeling a conduit run it would tell me how many degrees I have put into that conduit run.National electrical code requires that no conduit  run have more than 360 dgrees.After that a pull box is required .It would help if as I run the conduit throughout the building ,if I exceed the 360 degrees it would  prompt me that a pull bow is requred.Or another way if after I finish the run I have a option that would add the pull boxes as needed.Any help?
0 REPLIES 0
