AutoCAD MEP Wishes (Read Only)
Message 1 of 1
945 Views, 0 Replies
Circuit Manager
When will Circuit manager become a worthwile utility.
I need to be able to work with lighting, small power, power and distribution constructs so that I only have to position a distribution board once in a project. In a plant room a panel may need to appear on a mechanical layout as well.
I need to be able to connect devices on the lighting and power constructs to the distribution boards on the distribution board constructs.
I need to be able to connect the distribution boards/panels together as necessary.
I need to be able to export the data to a thirdparty software such as Amtech and import the results back again for my Schematic.
http://www.amtech-power.co.uk/
As it is I doubt if an electrical engineer even looked at it.
0 REPLIES 0
