Mike, I could not agree with you more. Let me post another reason why Autodesk need to make this available again. In some instances, we could have som 200-500 vertical pipes (stacks or risers) that need to all terminate at the same location in the Z axis. In ABS 2006 we would accomplish this task in a few seconds by selecting all pipes, going to the properties tool palette, and changing the "Start/End Point Z" value to the one needed. Vioala!!! All pipes stretch to this new Z value without having to modify them individually as we have to now. If Autodesk uses the increase in productivity as one of it's product upgrades selling point, how come tools like these are being removed from earlier versions. I can understand if they replace a tool with a better one, but not deleting it completely without giving you a workaround that takes the same or less time to achieve the final result.
