I just had a client request this add feature, it should be easy:
When using the Size Schematic Pipe command, the software currently shows how
many Fixture Units are used in the calculations, my client would also like
to see how many Fixtures are used in that calculation - currently the only
way to do this is to use the 'Show Objects for Sizing' command, then
manually count the highlighted fixtures. A simple uneditable field in the
sizing dialog box that shows the # of fixtures upstream would be great!
Dustin
