I whole-heartedly agree with you. I layout the ceiling grid/fixtures and
currently we simply layout the grid using the ceiling grid tool, drop in our
"devices" and explode and trim the grid if any fixtures cross a grid
section. It's a pain but currently the only viable solution IMO. I hear
you can work around it and make a device just for the connection points but
you still have to insert every fixture twice. Oh and make it work through
the xref barrier 😃
"Mike Abernethy" wrote in message
news:0B92EDD29EEF4D465176B6CD9A380763@in.WebX.maYIadrTaRb...
> The lighting designer usually lays out the ceiling grid and light
fixtures,
> not the architect.
> Light fixtures in Building systems are not the same fixtures in
> Architectural desktop and therefore are not anchorable and incapable of
> masking the ceiling grids.
> There needs to be some way for the Building systems light fixtures to be
> Anchorable to and masking of the Architectural ceiling grids.
> That way, if the room configuration changes and the ceiling grid is moved,
> the light fixtures will follow.
> Currently, we have to draw the ceiling grids in Architectural, then locate
> the light fixtures in Building systems xref'd to the ceiling plan. Then,
in
> order to mask the grid, we have to open the ceiling plan, xref the
> electrical lighting plan and insert the Architectural lighting symbols
over
> the Electrical symbols.
> As one of the few full users of the Architectural Desktop and building
> systems 2004 packages, I can tell you this is one extra drawing step we
> hadn't counted on!
> It gets to be quite a chore when you are looking at a building with
thousads
> of fixtures.
> All of the above also applies to the mechanical design objects such as
> ceiling diffusers.
> Please try to find a way to use the MEP objects with masking and anchoring
> in the Architectural ceiling grids.
