It would be very useful if calculated values that are marked as visible were
exposed in the add dialog filter tab. Constants and lists are exposed but
for some reason calculated values are not.
A good example of this: You have a calculation that takes a list parameter
value for CFM and the duct connector size then calculates velocity. This way
you could adjust your other values to get the required velocity without
having to resort to a calculator.
Shane
