AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
XREF invalid in MEP2013
3 REPLIES 3
luxy72462
1007 Views, 3 Replies
I just upgraded from MEP 2010 to 2013 a few weeks ago and I am having an issue with XREFS. I can set up a new drawing and get my background and titleblock in but anything more than 2 xrefs and I just get an invalid error and it won't load anymore. It blips on the screen like it has been inserted then its disappears and I just get the invalid error. I have tried saving some of the Xrefs to my desktop instead of the server thinking maybe there is a link issue. Is there a setting in the options that regulates the amount of XRefs you can retain in a single drawing? Any help would be appreciated. It's getting tedious creating blocks from the drawings I would like xref'd and dropping them into my drawing and freezing and unfreezing them.
Josh
3 REPLIES 3
Joshua.Benoist
in reply to: luxy72462
Are you aware that 2013 was a file format change?  Were the xref files created in a prior release, or were they also created in 2013?
Joshua
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
luxy72462
The architect I work with uses CAD architecture 2010. If this is a file issue I dont see why Autdesk would create this incompatibility and not allow you to Xref in an older .dwg.
jpuck91
This is a known issue with all the 2013 products (http://forums.autodesk.com/t5/AutoCAD-2013/xrefs-not-loading/td-p/3397393), and was specifically addressed in Autocad 2013 SP1.1... when is the service pack or patch for MEP coming out that includes this?
”Boost
