AutoCAD MEP General Discussion
Active Member
itsupport
Message 1 of 2 (169 Views)
Wires
169 Views, 1 Replies
07-14-2009 08:50 AM
Does anyone know why it is that when devices and wires are copied the wires screw up (see attached) The same thing sometimes happens with the move command but the result is inconsistent, sometimes it works sometimes not.
New Member
jklees
Message 2 of 2 (169 Views)
Re: Wires
07-14-2009 09:12 AM in reply to: itsupport
make sure when your copying it over your osnap is off, sometimes MEP objects will snap to a different elevation and screw up your display, same with move, ive found the best way to move is by using the grips with osnap off. just my suggestion, dont know if thats what is really going on here though.
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
