Is AutoCAD using window based driver for plotting now I just installed MEP 2013 and noticed there is no plotter wizard.
Solved by Joshua.Benoist. Go to Solution.
It installs with AutoCAD Architecture 2013 and is in:
C:\ProgramData\Autodesk\ACA 2013\enu\Plotters
I will pass along to the developers that it is indeed missing in AutoCAD MEP 2013.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
