In the Lower left corner of the screen is a small back arrow in a circle.
Right click on it and select "Link to Viz Render".
If you still cannot see it, please make sure that the Drawing Staus Bar is
toggled on.
i.e. you should also be able to see the Scale and current display
configuration.
Regards
Rob Finch
Software QA Analyst
Autodesk, Inc.
"clarkm" wrote in message
news:18374067.1088098945084.JavaMail.jive@jiveforum2.autodesk.com...
> I know where the program is, but there is a command "Link to Viz Render"
in AutoCAD that is suppose to link your AutoCAD drawing to Vis Render?
