AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
What's that dot on my devices?
4 REPLIES 4
558 Views, 4 Replies
That one, right there. It's not an insertion point or connector. Doesn't
appear to be part of the view block, either.
4 REPLIES 4
Martin__Schmid
I suspect it actually is the connector... at least some artifact of the connector.
I.e., if you go to the Display tab of the Properties Palette.
At the bottom , click the Select Component button, then click on the dot, I suspect that it will select the Connector Display component... which, typically by default, is turned off.
This dot is placed according to the connector position defined in the style. I.e., if you modify those values, the position of the dot moves. What is odd, however, is that the position of the dot doesn't scale according to the drawing scale nor the annotation plot size.
Martin Schmid
Product Line Manager
Mechanical Detailing and Electrical Design
Architecture, Engineering, and Construction
Autodesk, Inc.
it may be a point. set pdmode to 1 and it will not show/plot
wrote in message
news:6340415@discussion.autodesk.com...
connector.
PDMODE doesn't affect it. As Martin said, it's a vestige of the connector. I
can turn it off in display manager. Its location matches the connector
location defined in the style. For example, my duplex outlet has its
connector at 0,3/4,0 and the dot is 3/4" up from the connector's insertion
point regardless of the anno scale. (Not any kind of a problem, by the way,
just a curiosity.)
MuirEng
I know this is an old post, but how do I turn the connector dot off in Display Manager? I don't see an item related to electrical connector. Tried turning "wire" off but that doesn't do it...
wait, just figured it out!
(representations by object - device)
Brian Muir, P.Eng, Muir Engineering
__________________________________________
Please vote up these ideas
Declutter Family Browser,
Electrical Panel Name Handling,
Dedicated Sub Forum For Electrical
Thanks!
”Boost
