We regular survey customers (plumbers, HVAC, etc) to gather information regarding the application and the content. the number one complaint over the last 2 releases was the inability to layout gravity piping systems, so we focused in on that group with a new approach to laying out piping with Angle of Deflection and extensive sanitary content. We try to get all the content needed, but we are not 100% perfect.
We do however, provide a way for users to create their own content thru Content Builder (Manage Tab Conent Panel) or Parametric Part Wizard on the Home Tab Tool Panel Drop list.
In the Parametric Part Wizard we supply Template parts that allow you to fill out the required dimensions and store the part in the catalog.
If you are a bit more of an advanced user, you can go directly into Content Builder and create Parametric fittings, and equipment to your specifications. You can also open up existing content and save it to a new part family and edit the values / parameters to meet your specifications.
Again, if you have a specific list of fittings that you think should be in the application please send them along (Mfg and Cut sheets are very appreciated).
Thank you,
Gregg Stanley [Autodesk]
Gregg Stanley
QA Analyst
AEC
Autodesk, Inc.
