AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
W BLOCK PROBLEM
1 REPLY 1
shavezkhan
222 Views, 1 Reply
W BLOCK PROBLEM
hi,i using autocad 2014,i have one drawing there are many layers some are off,freez,
so when i making w block file that time those freez or off layers also came in that file.
is there any way to avoid those off layer which will not include in the w block
plz suggest me
1 REPLY 1
marco.defina
in reply to: shavezkhan
maybe the layers that you don't want are in a block, and if are freeze come togheter independently.
BIM Manager - HVAC and Plumbing designer https://www.autodesk.it/content/dam/autodesk/www/products/responsive-imagery/responsive-badges-compare/2019/navisworks-manage-2019-badge-75x75.pngApp AutoCAD per dispositivi mobili premiumNavisWorks Simulate3ds Max___________________________________________________________________________
Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums.
”Boost
