Are you using the Project Navigator? If so then you can set the layer key for VIEWPORT to the correct layer.
Regarding the template issue, if you have a particular template that you use for new drawings go into this template and create the new layer with the appropriate properties then save the template, any new drawing based on this template will include the layer.
Drew
North Vancouver
