AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Valve annotation placed very far
3 REPLIES 3
andre_adc-dao
426 Views, 3 Replies
In MEP 2015 when I place a valve the annotation is not place near the valve but very far. This happen only when I use imperial template, metric is ok. I have install English version follow by French language pack installation.
Any idea how to correct that?
André
3 REPLIES 3
I apologize, I'm new with MEP product and I think I doesn't understand everything. When I test valve insertion with imperial drawing, I have loaded a metric profile. If I start MEP with USImperial profile I doesn't have the same result. I think it is important to load the corresponding profile, not only the template. Am I wrong?
André
Hi Andre,
Thank you for posting. What you've stated in your second post is correct: If you are working in Imperial units (the Imperial profile), you should also be working with an Imperial template/drawing. The same goes for Metric. Did working in the corresponding profile and drawing resolve the issue with the valve annotation placement for you?
Victoria Studley
Content Experience Designer - Fusion 360
Fusion 360 | Learn & Support
Documentation | Contact Support
Thank you,
This solved this problem.
André
”Boost
