AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Turn Fitting 90°
2 REPLIES 2
MEP_CAD
727 Views, 2 Replies
Turn Fitting 90°
I'm yousing AutoCAD MEP 2013
when i turn a Fitting with grip ( and ctrl) for 90° it will ohnly turn the hole fitting for 90° the connection to the duct will lost. In 2012 the fitting was adjusted (changing high and width).
This functionlity is not useful. Is there a trick to get the funtionality of 2012?
Thanks for any replay and help.
2 REPLIES 2
Joshua.Benoist
in reply to: MEP_CAD
Thank you for reporting this change in behavior between 2012 and 2013.  We were able to recreate the issue.  We have reported this to the development team.  They are aware and will be looking into this.
Have a great day.
Thank you,
Joshua
Joshua Benoist, PE
Senior Premium Services Specialist
Global Services
Autodesk, Inc.
MEP_CAD
in reply to: Joshua.Benoist
Hello Joshua
Now we have updateted to MEP 2014
This error is not resolved. In 2014 is the same than in 2013!
Can you check again.
Thank best regards Robert
”Boost
