AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Translucent SHP polygon
2 REPLIES 2
othen
357 Views, 2 Replies
Hi.
I need to print a map, which is covered with SHP polygons. I added translucent fill, but in printing there is no translucent.
Please, help! Thanks anyway.
2 REPLIES 2
in reply to: othen
Make sure "Plot transparency" is checked under Plot options.  You may have to click the "More Options" button at the bottom right of the plot dialog to expand the window so you can see selections controlling plot styles, orientation, etc.
Good luck!
othen
in reply to: othen
Thanks, but I've already check it and it's the same situacion - no transparency in hard copy. 😞
But this problem exist only when I have poligons from loaded shp file. When I print polylines with transparent hatch - everything is ok.
”Boost
