AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Toggling between overlapping lines
3 REPLIES 3
michaelrouse4488
2096 Views, 3 Replies
In AutoCAD 2000, there was a neat feature that allowed the draftsman to toggle between overlapping lines by holding Ctrl and clicking over them. I have yet been able to find a similar feature in AutoCAD MEP... Was this taken out or turned off? And if turned off where do I go to turn it back on?
3 REPLIES 3
ncassidy
in reply to: michaelrouse4488
To cycle through overlapping objects, roll over the object on top, then hold SHIFT and press SPACEBAR repeatedly.
To cycle through overlapping subobjects (faces, edges, and vertices) on 3D Solids, roll over the subobject on top, then hold CTRL and press SPACEBAR repeatedly.
Yep, that works!
Thanks again
Matt__W
Or you can change your LEGACYCTRLPICK variable.
Matt W
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
”Boost
