Hi again.
I'm using IE6 with all patches inc. latest SP, whichever it is.
After using repairtoday.exe I've got the soundest advice from the software:
"If none of these options works, turn off Today. Then try turning on Today
at a later date to see if your problem has been fixed.", which did not
improve the matter but it did greatly improve my mood. I think I will follow
this advice for a little while:-).
BTW, after the repair my R14 opens verry fast!!
sp
"Jim Borries" wrote in message
news:F6F0CE526DE6BD7BE5E649BD8A9E6539@in.WebX.maYIadrTaRb...
> Are you using IE 5.5 with the latest SP (security patch)? I think there
is
> a problem with Today and this version. You will probably need to go to IE
> 6.
> Jim B.
> "Slawomir Popiel" wrote in message
> news:DB2F2844BF3E0D53660EEA8EC59B3B38@in.WebX.maYIadrTaRb...
> > Nah, I accepted default values. Will try that repair thing.
> > sp
> > "jason martin [Autodesk]" wrote in message
> > news:CB960994BF74C503E498876E18E3C873@in.WebX.maYIadrTaRb...
> > > Hi Slawomir -
> > > Did you by chance specify a today page location during a network
> install?
> > If
> > > you've specified a today page there it is possible to get these kind
of
> > > errors with today if it can't find the page that you specified.
> > > Something that "might" help would be to navigate to (assuming that
> you've
> > > installed to the default path) c:\Program Files\Autodesk Building
> Systems
> > > 3\WebDepot\ErrorHandler and running repairtoday.exe.
> > > hth
> > > jason martin
> > > Autodesk
> > > news:475340E03817824349D415768C9C2385@in.WebX.maYIadrTaRb...
> > > > I'm getting a series of following messages opening Today.
> > > > Can anybody tell me what's going on?
> > > > sp
> > > > A problem has been detected in Today.
> > > > Autodesk Components
> > > > Component Name Diagnosis Available Fix
> > > > Preview control Version is OK
> > > > DesignCenter control Version is OK
> > > > Today container control Version is OK
> > > > Point A banner control Version is OK
> > > > System Components
> > > > MS Internet Explorer Version is OK
> > > > JavaScript engine Version is OK
> > > > VBScript engine Version is OK
> > > > System OLE services Version is OK
> > > > The page cannot be found
> > > > The page you are looking for might have been removed, had its name
> > > changed,
> > > > or is temporarily unavailable.
> > > > Please try the following:
> > > > If you typed the page address in the Address bar, make sure that it
is
> > > > spelled correctly.
> > > > Open the pointa.autodesk.com home page, and then look for links to
the
> > > > information you want.
> > > > Click the Back button to try another link.
> > > > HTTP 404 - File not found
> > > > Internet Information Services
> > > > Technical Information (for support personnel)
> > > > More information:
> > > > Microsoft Support
> > > > Context: boot
> > > > Source file: Today.asp
> > > > Description: Object doesn't support this property or method
> > > > Error number: 800a01b6
