AutoCAD MEP General Discussion
Active Contributor
Buster1379
Message 1 of 7 (122 Views)
Title Marks
122 Views, 6 Replies
07-16-2003 11:11 PM
I want to modify the Title Mark A1 that comes standard with ABS, but it is an MVblock. All I want to do is delete the circle w/ number refrence from the block (creaate new block if I have to) If I just delete the reference (circle & number) from title Mark A1.dwg it no longe has any MV properties. ADT help didn't seem to helpful. Basically all I want is a title mark w/ no reference just title, scale, and customizable line of middle polyline.
*[Autodesk], jason martin
Message 2 of 7 (122 Views)
Re: Title Marks
07-17-2003 02:48 PM in reply to: Buster1379
------=_NextPart_001_001B_01C34CCE.B5C66D40
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
But the Title Mark isn't an MvBlock. It's just standard blocks wrapped =
in a custom command. Rather than deleting the block, you can do an =
in-place edit and just delete all of the stuff "inside" the block, then =
save it and it should work. See attached example image
jason
"Buster1379" wrote in message =
news:f1786a3.-1@WebX.maYIadrTaRb...
> I want to modify the Title Mark A1 that comes standard with ABS, but =
it is an MVblock. All I want to do is delete the circle w/ number =
refrence from the block (creaate new block if I have to) If I just =
delete the reference (circle & number) from title Mark A1.dwg it no =
longe has any MV properties. ADT help didn't seem to helpful. Basically =
all I want is a title mark w/ no reference just title, scale, and =
Content-Type: text/html;
charset=3Diso-8859-1">
But the Title Mark isn't an MvBlock. =
It's just=20
standard blocks wrapped in a custom command. Rather than deleting the =
block, you=20
can do an in-place edit and just delete all of the stuff "inside" the =
block,=20
then save it and it should work. See attached example image
3D"" src=3D"cid:001501c34cf0$3cb4cdd0$6501010a@amer.ads.autodesk.com" =
align=3Dbaseline=20
border=3D0>
jason
> I want to =
modify the Title=20
Mark A1 that comes standard with ABS, but it is an MVblock. All I want =
to do is=20
delete the circle w/ number refrence from the block (creaate new block =
if I have=20
to) If I just delete the reference (circle & number) from title Mark =
A1.dwg=20
it no longe has any MV properties. ADT help didn't seem to helpful. =
Basically=20
customizable=20
------=_NextPart_001_001B_01C34CCE.B5C66D40--
Message 3 of 7 (122 Views)
Re:
07-17-2003 02:55 PM in reply to: Buster1379
Well that didn't work. Try this one...
"jason martin [Autodesk]" wrote in message
news:98F01E36CBD70F5F3DD22C208043CE69@in.WebX.maYIadrTaRb...
But the Title Mark isn't an MvBlock. It's just standard blocks wrapped in a
custom command. Rather than deleting the block, you can do an in-place edit
and just delete all of the stuff "inside" the block, then save it and it
jason
Active Contributor
Buster1379
Message 4 of 7 (122 Views)
Re:
07-17-2003 08:26 PM in reply to: Buster1379
Jason,
Do you mean just perform a refedit while the existing block is in my drawing and save it back to the original file?
Buster1379
Message 5 of 7 (122 Views)
Re:
07-17-2003 08:38 PM in reply to: Buster1379
No, open the "content" drawing and do it there (actually make a copy of it
first and then edit it) was what I meant. I posted an avi to cf called
Example Title Mark Edit.
hth
jason
news:f1786a3.2@WebX.maYIadrTaRb...
> Jason,
> Buster1379
Active Contributor
Buster1379
Message 6 of 7 (122 Views)
Re:
07-17-2003 09:28 PM in reply to: Buster1379
Jason,
I can't open the AVI file with Windows Media Player or Quicktime
Buster1379
Message 7 of 7 (122 Views)
Re:
07-17-2003 09:41 PM in reply to: Buster1379
You need the techsmith codec to play the avi files. Try getting it from
http://www.techsmith.com/products/studio/codecdownload.asp
jason
news:f1786a3.4@WebX.maYIadrTaRb...
> Jason,
> Buster1379
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
