Hello, I'm trying to make a schedule table to count the meters of cable tray of a Project but I don't know how... In the example I have attached, I have a multiple meters of a same cable tray dimension. In the schedule table, it counts all of them and it shows the subtotal but I don't know how to show only the subtotals and hide the parcials counting. I would like to have a schedule table with only 4 rows (one for each cable tray dimension) and then another row with the TOTAL lenght of the cable tray dimension.
Solved by VitalyF. Go to Solution.
There is no way to do this, unfortunately !!!
I have written many times Wishlist...
Try to use this table with the formula
Set app = GetObject (,"AutoCAD.Application") On Error Resume Next RESULT = "--" Set baseApp = app.GetInterfaceObject("AecX.AecArchBaseApplication.7.7") Set ActiveDoc =baseApp.ActiveDocument Set ObjectCollection = ActiveDoc.ModelSpace totLength = 0 n = "[CableTrayObjects:PartSizeName]" For Each Object In ObjectCollection If Object.ObjectName = "AecbDbCableTray" Then If Object.SizeName = n Then totLength = totLength + Object.Length End if End If Next RESULT = Replace( Round((totLength)/1000,2), ",", ",")
For Autocad MEP2015
For Autocad MEP2014 change this string >>
Set baseApp = app.GetInterfaceObject("AecX.AecArchBaseApplication.7.5")
Vitaly
Hi VitalyF, I have addapted your Schedule Table for counting pipe and it works good but it takes a lot of time to "operate" the table. Also each time I open a DWG with this table. Is it normal? Thanks!
Thanks for your information but where is the option to convert a Schedule Table to a AutoCAD Table format. Is it relatively simple? Or where can I read about it to learn to do it. Thanks a lot!!
hi there. do you mind explaining how i can manipulate this formula to work with Eastcoast CAD piping? or any other piping that has special property sets?
