AutoCAD MEP Forum
Welcome to Autodesk’s AutoCAD MEP Forums. Share your knowledge, ask questions, and explore popular AutoCAD MEP topics.
Structural Columns and Beams
3 REPLIES 3
eze_90
1059 Views, 3 Replies
In the Arquitecture tab, when I insert a colum or a beam I can't modify their dimensions (height and wide for the beam for example). Any help? It just let me place the column or beam but not changing the standard.
Thanks!
3 REPLIES 3
davidclark70
in reply to: eze_90
eze,  When you installed MEP if you included Architecture on the install you will have the sturctural member catalog.  Use the command MEMBERCATALOG and you can choose your beam type from the catalog.
hope it helps, and hope you checked Architecture on the install....
eze_90
in reply to: davidclark70
thank you! I didn't find the button! the command worked just find! then I found the button! It is not an easy one, lol
swinter
I do not have Architectural catalogue installed, is this easy to add? I would have to go through my IT manager!
Can you advise please
Steve
”Boost
