AutoCAD MEP General Discussion
Member
eze_90
Message 1 of 3 (442 Views)
Structural Columns and Beams
442 Views, 2 Replies
09-05-2012 08:12 AM
In the Arquitecture tab, when I insert a colum or a beam I can't modify their dimensions (height and wide for the beam for example). Any help? It just let me place the column or beam but not changing the standard.
Thanks!
eze,  When you installed MEP if you included Architecture on the install you will have the sturctural member catalog.  Use the command MEMBERCATALOG and you can choose your beam type from the catalog.
hope it helps, and hope you checked Architecture on the install....
dvclark5
Message 2 of 3 (435 Views)
Re: Structural Columns and Beams
09-05-2012 11:21 AM in reply to: eze_90
Member
eze_90
Message 3 of 3 (420 Views)
09-06-2012 07:39 PM in reply to: dvclark5
thank you! I didn't find the button! the command worked just find! then I found the button! It is not an easy one, lol
New AutoCAD MEP Category!
The AutoCAD MEP forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
