CAN SOMEONE WALK THROUGH THE STEPS ON HOW TO MAKE THE "START ELEVATION / END ELEVATION" LABELS FOR PIPING SHOW FEET AND INCHES INSTEAD OF DECIMAL FEET. I AM USING OTB MEP 2011
Solved by jcampbell924. Go to Solution.
Jerry
Is my screenshot what you are after? Do you wan to use a label or a tag? My example below I used a label and added the Start Z and the End Z to the PipeObject property set. I then made a formula property that just combined the two together. I got them to display in feet and inches by changing the data format to Length - Long inside of my formula Property set. Let me know if this is what you want or if you want screen shots of what I did.
Jeff
JEFF,
I COULD NOT SEE YOUR SCREEN SHOTS. I HAVE ATTACHED MINE SO YOU CAN SEE. THESE ARE SHOWN AS LABELS IN THE TOOL PALLET.
This is how I fixed it.
1. Open up style manager
2. Expand out the documentation section
3. Expand out the Property Data Formats section (this controls how units are reported in a PSD)
4. Copy the Elevation - Feet and paste a copy into the Data Formats section. (I renamed my copy to Elevation - Feet-Inches)
5. Select the Elevation-Feet-Inches and change the settings per screen shot 1.
6. Expand out the Property Set Deffinitions section
7. Select the PipeInvertIn PSD (note that this is a style based PSD)
8. Edit the formula property Decimal_Feet_In and change the Format type from Elevation-Feet to use the Elevation-Feet-Inches that you created above. Screem shot 2
Select the pipe and tag and do a objrelupdate on them. The tag should update to display what you want to see. Screen shot 3
I did what you did. It looked exactly like yours. But the problem is the feet were never right. will you post a full screen shot so i can make sure all enities are checked properly
