I have an old... no longer valid property set definition in a dwg file.
I cannot seem to find which objects to which it is added.
I have classifications that relate... I've cleared and purge one of them that should have released it.
There are no Schedule definitions in the file... so this wouldn't be the culprit.
Help!
You can try exporting your drawing as a block. This will force MEP to only copy the items that are actually in use in your current drawing. It will leave all unused styles behind. Just make sure to not copy over your existing drawing and to make sure that you have objects placed in model space that hold all of the styles that you wish to keep.
If the style is still stubborn and is present in the new drawing then that means that it is attached to one of the objects that you placed in model space.
