The original of this message with attached file has been moved to
the Customer Files area
(news://discussion.autodesk.com/autodesk.autocad.customer-files
or http://discussion.autodesk.com/WebX?14@@.ee940b5). Please do
not post files into technical support groups. Zipping files is a
courtesy to those who download them.
See the newsgroup guidelines at
http://discussion.autodesk.com/webx?groundrules.
Anne Brown
Manager, Moderator
Autodesk Product Support discussion groups
Discussion Q&A: http://www.autodesk.com/discussion
Subject:
Re: Smooth radius transition elbow
Date:
Fri, 4 Apr 2003 08:04:03 -0800
"Peter Terwilliger [Autodesk]"
Organization:
Newsgroups:
autodesk.building.systems.3
Matt -
How have you tried to create the tee?
I would do it using the parametric part builder, draw the arc
with a short line at either end, and extrude a rectangular
profile using the path
feature.
I played with it for a few minutes - the jpg is what I came up
with. I am not happy with the inside radius of the elbow - it
should be a 90
degree arc.
I hope this helps...
File: BVH-CAD.jpg
